I'm currently running OpenSUSE Tumbleweed, and am running into an issue running Feral Interactive ports on Linux.
Feral games have that launcher where you can setup display and such, and I think there is a dependency issue or something. I ran into this a few weeks ago but didnt give it any thought.
I was just on an Arch machine playing Deus Ex: Mankind Divided and it was fine.
Other games like CS:GO, Rocket League etc run just fine. Just not Feral ports.
I have the 375.10 Nvidia driver installed. Thanks for any help!
EDIT: I'm asking here because Feral only offers support on Ubuntu and SteamOS.
Well, how do the issues manifest? If you're not getting an error message clicking on a menu entry, you can try running the corresponding executable from terminal and see what error it returns.
Some of the time, when launching Steam, I'd get an error saying it can't find anything in the $DISPLAY variable, so it thought X wasn't running or something.
Once I fixed that, whenever launching a game, I'd hit 'launch' on Feral games then it just sit and do nothing.
I came back later, then all of my games weren't launching, like Rocket League, where it was before.
So I decided to give Solus another shot, and Steam has been working very nicely on there.
I switched the proposal in the installation to use EXT4 for home and root.
The manual driver install worked fine on my 1070, but some of these issues start coming about. Feel like there is something else going on, or I'm being dumb, lol.
I have, and after a fresh OpenSUSE TW install, a second install always fixes it, at least temporarily. It seems like the 32-bit libraries install without a problem.
I've only tested KDE Plasma 5.8 with this situation.
But I have had this with both the vanilla OpenSUSE TW distro and the Gecko Linux Rolling spin.
This is 1000000% anecdotal, but I always have issues with KDE. I get poor frame rates in games, I get high audio latency, and then packages just randomly break.
Now if you run KDE with lightdm or even gdm, things seem to be better. I have no idea why. If anything, things should be worse, but the system becomes much more stable.
I know its not really your first choice, but you could install gnome or even the bungie DE and see if that does not fix your issue somewhat.
