Feminine PC Case
I am building a computer for my wife and am having trouble finding a case that is not overly masculine, It doesn't have to be overly feminine either. she is not really looking for anything in particular just needs to fit a micro atx but wants to keep the case through a few upgrades including to an atx board. do you all have any recommendations?
I happen to have the Corsair 600T. It's appropriate for mATX, or ATX motherboards. Doesn't strike me as a masculine design. Mid-sized tower, still with good radiator support, Corsair quality. Easy to work around.
phantom cases from nzxt?
I don't really know of any feminine cases but Fractal Design and Lian Li make some really high quality, neutral, and minimalistic cases.
Can we get a price range?
Off of the top of my head though, I would suggest you look at the Rosewill Blackhawk. I personally have this case, and dno't like anything too flashy/showy. Simple/sleek/elegant was what I was looking for and I found it in the Blackhawk. In most pictures that you will see of the case, the lights on the fans are really accentuated. They really aren't that big of a deal in the actual case, but I still cut the wires that go to them anyway (I don't want lights coming from my case). The mesh runs from the front and over the top. Very simple and refined look. I hope that is what you were looking for. Give us a little more information and I can probably make some more suggestions.
Also, any color preferences? White? Black? A mixture of black and white? Other colors?
EDIT: Found some cases which might be of interest.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345011
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163188
http://www.newegg.com/Product/Product.aspx?Item=9SIA0SF0R71458
Doesn't get more feminine than this case. Another one that is cheaper is this case from Rosewill. Personally I'd get a mini itx case like the prodigy and mod it so a micro atx fits if you can't wait for them to release the M.
*GASP* (clutches string of pearls)
I have the Phantom 630... What's so femmy about that case? XD
I'd go for a Bitfenix Prodigy, white perhaps? That way she could decorate with decals and such?
It has to fit a mAtx board in it, so that can't be an option.
Anohter good option would be the Corsair 350D.
Ha I have the White 410. She likes the red model but doesnt want the same case I have.
Cost isnt a big issue 75-125 usd and she has said yellow, red and pink. She will probably be happy with any color if the design is nice.
She is liking the the white case with decals idea. I found some nice ones on redbubble where do you get your?
Red NZXT cases.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146066
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146086
You are racist towards 1440p, 1600p, 2k, and 4k.
I didn't want it to be forever long, so I went with the most popular ones.
NOPE.
He's pro 16:9 and that's it
16:9 MASTER RACE!!!!
NOPE.
16:10 MASTER RACE
