Female 2 pin to molex help
A friend of mine just purchased two Bit Fenix Alchemy LED strips, and one came with out the 2 pin female to molex adapter. I wanted to know if there are any other solutions out there that would work, any info or links would be great. (He bought one new and one as a part of some deal, and that was the one that didn't include a cable.)
daisy chain it to the new one
order cable from Bit Fenix
make new cable from scratch
Alright, well with out anything to use for Daisy Chaining, and not wanting to go through making one for him, I guess we'll call up Bit Fenix and see if they can send us one. Thanks for the help.
the new one you bought did not have the daisy chain adapter in the box?
The way the daisy chain works is you're suppose to have both adapters, they're both suppose to have a cable that accepts the 2 pin, than a molex male and a molex female, you plug the molex male from your second adapter into the first and that's how it works I believe. I could be wrong, but when I was over helping him, that's the only thing that looks like it will work.
I thought there was a small coupling that just stabbed into the ends to continue the chain. Maybe i am thinking of  different light
