Feedback on Mini-Itx/Lan rig
Hi im planning on building a Mini-Itx/Lan system i would love some tips and Feedback
These are the parts
corsair-4gb-2x2048mb-cl9-1333mhz-xms
Intel Plentium g860
500GB Caviar Mobile
Gigabyte Radeon HD6677
fractal-design-integra-r2-500w-80-bronze
Asus P8Z77-I Deluxe Edition
Bitfenix Prodigy Mitx
Whats your budget?
I would change the HDD to a SSD if you can afford (lighter and better performace).
I don't like that CPU does not support hyper threading... I would get a icore 3 or 5
Love the case I would get a side window also for it
500-600 dollars Thanks for the feedback!
For that price range intel doesn't make sense, and a dual-core even with hyperthreading doesn't make sense if you want it to be a lasting investment. Definitely consider AMD (fx4300, fx6300, fx6350)
I want it to be future proof thats why
http://pcpartpicker.com/p/1czMO
I made this. I think its quite a neat little system. Comes to $609, so a tiny bit over budget.
If you wanted something a lot cheaper I'd recommened this
http://pcpartpicker.com/p/1czSo
Both are AMD but its best for this system.
Thanks alot Malcolm :)
