Fedora43 - Wine and Proton complete removal
Hello everyone, I am sorry but I need to ask assistance again. Being stubborn to install and make it work an old game, I have asked assistance to ChatGPT and now my Fedora is messed up (not a post against AI, but it doesn’t seem to be that Intelligent anyway).
I want to remove every single trace of Wine and Proton from F43, and reinstalling from scratch, by using the correct version (32bit if possible). So I have attempted to do a dnf list installed | grep -i wine but I have got no results, but if I do wine --version I get wine-10.0-rc4 as results. Winetricks seems to be corrupted, I have the icon showing up on my Apps, but it doesn’t launch and I cannot even uninstall it.
Also, I do use Heroic Game Launcher, and on the game I have installed, if I select the version of Proton or Wine I want to use, I have a very long list, but those are not even installed, so I am not sure how to clean this as well.
I know, it’s a mess, but I have learned a lesson that I won’t repeat it again. Can someone help me to clean up all this mess by completely remove Wine and Proton, and install them from scratch? Thanks a lot!
IIRC 32 bit x86 based binaries are being removed from Linux at large. Your best bet is to use containers such as flatpaks or maybe AppImages.
check if rpm shows it…
rpm -qa | grep -i wine
also check where its at…
which wine
and use dnf provides on that to see what the name of the package might be… might not have wine in the name…
By executing pm -qa | grep -i wine i get:
wine-devel-11.0.rc4-1.1.x86_64
winehq-devel-11.0.rc4-1.1.x86_64
With which wine i get:
/usr/bin/wine
How do I proceed from here? Also, how do I make winetricks disappear from my system (even the icon from the App list)?
dnf remove wine*
Well, prevent the expansion:
dnf remove "wine*"
or
dnf remove wine\*
shouldnt be needed… but probably wont hurt
Maybe more important is ending with dnf autoremove ?
Thanks for the guidance. Executing dnf remove "wine*" I get this result:
Removing:
wine-devel x86_64 1:11.0.rc4-1.1 WineHQ 1.4 GiB
winehq-devel x86_64 1:11.0.rc4-1.1 WineHQ 62.1 KiB
Removing unused dependencies:
unixODBC x86_64 2.3.12-7.fc43 fedora 1.0 MiB
I have confirmed the deletion, but then when I execute this command dnf list installed wine* I get this:
Repositories loaded.
Available packages
wine.i686 10.20-5.fc43 updates
wine.x86_64 10.20-5.fc43 updates
wine-alsa.i686 10.20-5.fc43 updates
wine-alsa.x86_64 10.20-5.fc43 updates
wine-arial-fonts.noarch 10.15-1.fc43 fedora
wine-arial-winefonts.noarch 10.20-5.fc43 updates
wine-cms.i686 10.20-5.fc43 updates
wine-cms.x86_64 10.20-5.fc43 updates
wine-common.noarch 10.20-5.fc43 updates
wine-core.i686 10.20-5.fc43 updates
wine-core.x86_64 10.20-5.fc43 updates
wine-courier-fonts.noarch 10.15-1.fc43 fedora
wine-courier-winefonts.noarch 10.20-5.fc43 updates
wine-desktop.noarch 10.20-5.fc43 updates
wine-devel.i686 10.20-5.fc43 updates
wine-devel.src 1:11.0.rc4-1.1 WineHQ
wine-devel.x86_64 1:11.0.rc4-1.1 WineHQ
wine-devel-devel.x86_64 1:11.0.rc4-1.1 WineHQ
wine-dxvk.x86_64 2.7.1-5.fc43 updates
wine-dxvk-d3d10.x86_64 2.7.1-5.fc43 updates
wine-dxvk-d3d8.x86_64 2.7.1-5.fc43 updates
wine-dxvk-d3d9.x86_64 2.7.1-5.fc43 updates
wine-dxvk-dxgi.x86_64 2.7.1-5.fc43 updates
wine-filesystem.noarch 10.20-5.fc43 updates
wine-fixedsys-fonts.noarch 10.15-1.fc43 fedora
wine-fixedsys-winefonts.noarch 10.20-5.fc43 updates
wine-fonts.noarch 10.15-1.fc43 fedora
wine-ldap.i686 10.20-5.fc43 updates
wine-ldap.x86_64 10.20-5.fc43 updates
wine-marlett-fonts.noarch 10.15-1.fc43 fedora
wine-marlett-winefonts.noarch 10.20-5.fc43 updates
wine-mono.noarch 10.3.0-1.fc43 updates
wine-ms-sans-serif-fonts.noarch 10.15-1.fc43 fedora
wine-ms-sans-serif-winefonts.noarch 10.20-5.fc43 updates
wine-opencl.i686 10.20-5.fc43 updates
wine-opencl.x86_64 10.20-5.fc43 updates
wine-pulseaudio.i686 10.20-5.fc43 updates
wine-pulseaudio.x86_64 10.20-5.fc43 updates
wine-small-fonts.noarch 10.15-1.fc43 fedora
wine-small-winefonts.noarch 10.20-5.fc43 updates
wine-smartcard.i686 10.20-5.fc43 updates
wine-smartcard.x86_64 10.20-5.fc43 updates
wine-staging.src 1:11.0.rc4-1.1 WineHQ
wine-staging.x86_64 1:11.0.rc4-1.1 WineHQ
wine-staging-devel.x86_64 1:11.0.rc4-1.1 WineHQ
wine-symbol-fonts.noarch 10.15-1.fc43 fedora
wine-symbol-winefonts.noarch 10.20-5.fc43 updates
wine-system-fonts.noarch 10.15-1.fc43 fedora
wine-system-winefonts.noarch 10.20-5.fc43 updates
wine-systemd.noarch 10.20-5.fc43 updates
wine-tahoma-fonts.noarch 10.15-1.fc43 fedora
wine-tahoma-fonts-system.noarch 10.20-5.fc43 updates
wine-tahoma-winefonts.noarch 10.20-5.fc43 updates
wine-times-new-roman-fonts.noarch 10.15-1.fc43 fedora
wine-times-new-roman-fonts-system.noarch 10.20-5.fc43 updates
wine-times-new-roman-winefonts.noarch 10.20-5.fc43 updates
wine-twain.i686 10.20-5.fc43 updates
wine-twain.x86_64 10.20-5.fc43 updates
wine-webdings-fonts.noarch 10.15-1.fc43 fedora
wine-webdings-winefonts.noarch 10.20-5.fc43 updates
wine-winefonts.noarch 10.20-5.fc43 updates
wine-wingdings-fonts.noarch 10.15-1.fc43 fedora
wine-wingdings-fonts-system.noarch 10.20-5.fc43 updates
wine-wingdings-winefonts.noarch 10.20-5.fc43 updates
wineglass.x86_64 1.2.1-6.20191110git7b2558e.12.fc43 fedora
winehq-devel.x86_64 1:11.0.rc4-1.1 WineHQ
winehq-staging.x86_64 1:11.0.rc4-1.1 WineHQ
winetricks.noarch 20250102-3.fc43 fedora
I don’t understand if these packages are installed or if they are available to install, so I am not sure what should I do with these. I will wait for your confirmation before asking any next step.
Additionally, wine --version now returns this:
bash: wine: command not found…
Packages providing this file are:
‘wine-core’
‘winehq-devel’
‘winehq-staging’
since they are listed under
" Available packages "
that means they are not installed
Thanks a lot. And what about Winetricks? It seems to be installed but probably it is corrupted. Executing winetricks --version I get this response:
Executing cd /usr/bin
20250102-next - sha256sum: 7f29a4ec7c559af18e88f1c0d012c2b0873c5228158511c3b5f4c9b127b9a733
I don’t understand what this means to be honest.
Should I also remove these?
sudo find / -iname “wine*”
.cache/wine
.cache/wine/wine-mono-10.1.0-x86.msi
.cache/wine/wine-mono-10.2.0-x86.msi
.cache/wine/wine-gecko-2.47.4-x86.msi
.cache/wine/wine-mono-10.4.1-x86.msi
.cache/winetricks
.cache/libdnf5/WineHQ-1aec7e334ce6d0a8
.cache/libdnf5/WineHQ-1aec7e334ce6d0a8/solv/WineHQ.solv
.cache/lutris/shaders/wine
They are cached files…
Probably not a good idea to have multiple versions of wine installed on your system. In fact, you rarely have any need to have wine installed on your system anyway, unless you like using some windows utility to do linux stuff, like edit text files with notepad instead of a good text editor that your OS already ships with, for some weird reason.
If you are already using heroic or lutris to launch your games, you can just let those handle your wine versions instead.
If you want to launch games manually with different versions of wine, just include those with the games, along with winetricks (it’s literally just a small text file). That also protects you from having a wine update break your game.
Well, initially I have installed DaVinci Resolve and Affinity Photo, the procedure to install both of them were requiring also installing Wine and a very complicated setup. Turned it that I don’t need both these softwares, DaVinci is not what I was really looking for and Affinity Photo, well, just got replaced by a proper Linux version, so I will uninstall them both. As for games, yes, I always use Heroic for non-steam games and Steam, so wine/proton are handled by them both.
But all the issue for which I have opened this thread, is because I was trying to install and run an old game, there are guide on YT showing that it is working on Linux, but for me didn’t work, so I have used chatGPT to guide me through, and it did a mess, so I am trying to fix all the issues and making Wine working again.
Anyway, what should I with these cached Wine version? Should I remove them manually or I should leave them?
From the looks of it, the only thing that might be useful are the cached shaders by lutris.
Ok thanks, I am going to delete them all but I’ll keep the Lutris one. I will still need help for Winetricks to remove it completely from my system and to reinstall it correctly
Because you’re using the wrong command.
If you want to pipe and grep something, check the output of what you’re piping first…
❯ dnf list installed
Updating and loading repositories:
 Fedora 42 - x86_64 - Updates                                                   100% |  19.9 KiB/s |   8.0 KiB |  00m00s
No matching packages to list
What you want is this:
❯ dnf list --installed
Installed packages
Box2D.x86_64                                         2.4.2-3.fc42                         fedora
GConf2.x86_64                                        3.2.6-44.fc42                        fedora
GeoIP.x86_64                                         1.6.12-20.fc42                       fedora
GeoIP-GeoLite-data.noarch                            2018.06-18.fc42                      fedora
Or more specifically this:
❯ dnf list --installed "*wine*"
Installed packages
mingw32-wine-gecko.noarch                2.47.4-4.fc40 fedora
mingw64-wine-gecko.noarch                2.47.4-4.fc40 fedora
q4wine.x86_64                            1.4.1-1.fc42  updates
wine.x86_64                              10.15-1.fc42  <unknown>
wine-alsa.i686                           10.15-1.fc42  <unknown>
wine-alsa.x86_64                         10.15-1.fc42  <unknown>
Similarly, you’re telling DNF to list packages named installed or wine*.
Not really productive and also untrue. There are no plans currently to remove 32 bit from Fedora, much less Wine’s 32 bit builds. There was a proposal, which was rescinded after the proposal discussion.
Debian is probably also keeping around 32 bit for eternity.
The Kernel can already handle the Year 2038 problem last I checked. It’s just down to individual applications that may or may not break.
DaVInci Resolve has linux versions that don’t require Wine…
I thought we were on the path of completely deprecating stuff. I had not really kept up with the news because I had to wipe out all of my podcast as I no longer had a long commute. There was also the news last year so I guess it did not go through?
I didn’t read the article TBCH.
I mean it does say it right in the headline…
32-bit support continues …
Weird that was not the title of the article once you click on it. But yes.
This was the title inside.
Fedora 44 and the 32-bit support debate: controversy, repercussions, and uncertain future
Article, why you betray me with altered title? lol
It was planned at one point but it was pushed through. Anyway I got your point that the 32 bit binaries are no longer removed.
