Fedora not installing on DL380 G6
Hi I am trying to install Fedora Server 22 on my HP DL380 G6 I keep getting this come up after the first fedora screen.
I type exit after that and get this
I then start scanning through journalctl then I get these few interesting message about the CPU and BIOS
Then this
Is this when you try and load the installer? If so, is this the DVD image written onto a USB? If so, did you use a universal tool to write said image to USB? If so, its a well documented case.
The root of the problem is that the drive paths are not being set correctly, as can be seen in your first image. With dracut-initqueue complaining about the paths.
I used fufus, I will try that.
Thanks
That didn't fix the issue, it still does the same thing.
Thanks
Just going off the images provided, bios update? Try contacting HP if a BIOS update/flash is available?
Hi, I have tried updating BIOS using the methods outlined on Fedora's website and still not working.
This is frustrating, any ideas?
