Fedora installation/porting due to motherboard change
I’m changing my motherboard and was wondering if there is a way to kind of port my installaed Fedora 28 on to the new hardware instead of installing new.
Put hard drive in new mother board.
Turn on.
Assuming it’s a standard motherboard you shouldn’t have issues.
May need to check some boot settings depending on what you do.
sounds promissing.
my current motherboard is the ASRock AB350M PRO
new one will be Crosshair Hero VII X470
so I guess this counts as nothing special?
usually if somethings supposed to work without a lot of hustle I get the toughest nut to crack, this time everything went bueno.
