After starting make install, I get errors about my DKMS modules, like:
sh ./arch/x86/boot/install.sh 4.13.9nptpatch+ arch/x86/boot/bzImage \
System.map "/boot"
grubby fatal error: unable to find a suitable template
Error! Bad return status for module build on kernel: 4.13.9nptpatch+ (x86_64)
Consult /var/lib/dkms/nvidia/384.90/build/make.log for more information.
This is the content of the make.log:
DKMS make.log for nvidia-384.90 for kernel 4.13.9nptpatch+ (x86_64)
Fr 27. Okt 23:29:24 CEST 2017
Makefile:19: /Kbuild: No such file or directory
make[2]: *** Keine Regel, um „/Kbuild“ zu erstellen. Schluss.
Did I name it wrong? Should there be a dash before nptpatch and what about the +?
The name is fine (Mine was called ‘-npt’ and I had v4.14-rc6 checked out, resulting in two dashes). The + is default behaviour, I don’t think it causes this issue. I don’t have experience with proprietary drivers with custom kernels. Maybe the NVidia driver doesn’t support kernel 4.13.9 yet. I think you would have better luck in the small linux tread at this point…
I’m running 4.13.9 right know, so that’s not the issue. I installed the zfs, spl and nvidia modules manually, but my system didn’t boot up with the new kernel
Can I somehow create a github repo that follows the fedora kernel repo and applies the patches to every new branch? I really don’t have much experience there.
Hi all i followed MichaelS guide Ryzen Virtualization Success (GTX 1080ti passthrough with Windows 10 client) and managed somehow to get a win8.1 vm going however the gaming performance hurts my eyes i get 30fps in dota2 native is around +120fps so i was wondering if it was possible using the steps mention above to patch my kernel 4.13.11-200.fc26.x86_64 with the npt patch or will everything break if someone has done this pls let me know
Think of the kernel as the tires on your car. They support the entire vehicle and you change them every 50k miles or so and it doesn’t adversely affect anything as long as they’ve been installed properly.
followed your instructions and i got an error at the last step while building got the following
Patch failed at 0128
The copy of the patch that failed is found in: .git/rebase-apply/patch
When you have resolved this problem, run “git am --continue”.
If you prefer to skip this patch, run “git am --skip” instead.
To restore the original branch and stop patching, run “git am --abort”.
error: Bad exit status from /var/tmp/rpm-tmp.DBLOHP (%prep)
