if you used the dot D folders for config files… then you’ll minimize the chance of running into rpmconf merge issues
Well luckily I document when I make changes to any of the system config files, and there’s only been 3 I had to do, 2 for pulse/alsa, one for sssd because I couldn’t add users to groups, see here. So I think I should be fine on that front?
Well anyway yesterday before heading to bed I thought… why not just do a hybrid approach - upgrade first, if something goes wrong or is messed up after the upgrade I can still reinstall right…
Well, I’m hung up on the first step:
[tarulia@localhost]~% sudo dnf system-upgrade download --releasever=34 | tee -a upgrade_34.log
Before you continue ensure that your system is fully upgraded by running "dnf --refresh upgrade". Do you want to continue [y/N]: y
Copr repo for Signal-Desktop owned by luminoso 9.4 kB/s | 3.3 kB 00:00
Copr repo for scrcpy owned by zeno 8.5 kB/s | 3.3 kB 00:00
Fedora 34 - x86_64 136 kB/s | 24 kB 00:00
Fedora 34 openh264 (From Cisco) - x86_64 9.2 kB/s | 990 B 00:00
Fedora Modular 34 - x86_64 172 kB/s | 24 kB 00:00
Fedora 34 - x86_64 - Updates 128 kB/s | 17 kB 00:00
Fedora 34 - x86_64 - Updates 1.1 MB/s | 517 kB 00:00
Fedora Modular 34 - x86_64 - Updates 153 kB/s | 22 kB 00:00
RPM Fusion for Fedora 34 - Free 47 kB/s | 3.8 kB 00:00
RPM Fusion for Fedora 34 - Free - Updates 50 kB/s | 3.6 kB 00:00
RPM Fusion for Fedora 34 - Nonfree 56 kB/s | 4.2 kB 00:00
RPM Fusion for Fedora 34 - Nonfree - Updates 48 kB/s | 4.0 kB 00:00
vivaldi-snapshot 23 kB/s | 2.9 kB 00:00
WineHQ packages 27 kB/s | 3.3 kB 00:00
No match for group package "kexec-tools-anaconda-addon"
No match for group package "dvdrip"
No match for group package "xcdroast"
No match for group package "totem-lirc"
No match for group package "pnmixer"
No match for group package "gstreamer-plugins-bad-free"
No match for group package "gnomebaker"
No match for group package "nyquist"
No match for group package "gstreamer-plugins-bad-nonfree"
No match for group package "gstreamer-ffmpeg"
No match for group package "vdr-tvonscreen"
No match for group package "decibel-audio-player"
No match for group package "dnf-yum"
No match for group package "gstreamer-plugins-ugly"
No match for group package "lame-mp3x"
No match for group package "plasma-user-manager"
No match for group package "gnomad2"
No match for group package "sphinxtrain"
No match for group package "csound-csoundac"
No match for group package "vdr-skinsoppalusikka"
No match for group package "whaawmp"
No match for group package "paratype-pt-sans-fonts"
No match for group package "libguestfs-tools"
No match for group package "pyvnc2swf"
No match for group package "totem-nautilus"
No match for group package "adplay"
No match for group package "sonic-visualiser-freeworld"
No match for group package "banshee"
No match for group package "xmms-adplug"
No match for group package "tclabc"
No match for group package "transcode"
No match for group package "fedora-release-notes"
No match for group package "cmusphinx3"
No match for group package "phonon-backend-gstreamer"
No match for group package "gstreamer-plugins-good"
No match for group package "chromium-libs-media-freeworld"
No match for group package "k9copy"
No match for group package "vdr-ttxtsubs"
No match for group package "kplayer"
No match for group package "tomahawk"
Error:
Problem: rdma-core-35.0-1.fc33.i686 has inferior architecture
- rdma-core-35.0-1.fc33.x86_64 does not belong to a distupgrade repository
- problem with installed package rdma-core-35.0-1.fc33.i686
(try to add '--skip-broken' to skip uninstallable packages)
Not sure why it’s not finding the groups, but that’s not something that I’m concerned about.
I’m not sure what it’s telling me with rdma-core
considering that rdma is part of the kernel (I believe?), this worries me a bit
Thing is, currently installed are both architectures:
[tarulia@localhost]~% dnf info rdma-core
Fedora 33 - x86_64 - Updates 137 kB/s | 17 kB 00:00
Fedora 33 - x86_64 - Updates 3.3 MB/s | 3.1 MB 00:00
Fedora Modular 33 - x86_64 - Updates 145 kB/s | 21 kB 00:00
vivaldi-snapshot 43 kB/s | 11 kB 00:00
Installed Packages
Version : 35.0
Release : 1.fc33
Architecture : i686
Source : rdma-core-35.0-1.fc33.src.rpm
Repository : @System
From repo : updates
Summary : RDMA core userspace libraries and daemons
URL : https://github.com/linux-rdma/rdma-core
License : GPLv2 or BSD
Description : RDMA core userspace infrastructure and documentation, including initialization
: scripts, kernel driver-specific modprobe override configs, IPoIB network
: scripts, dracut rules, and the rdma-ndd utility.
Version : 35.0
Release : 1.fc33
Architecture : x86_64
From repo : updates
So it’s not like it’s a downgrade?
Or is it telling me there’s no package for the x64 version in F34? Could hardly believe that… and how would I even check that (with system tools that is)?
Ive updated 3 of my systems so far… none of them had any issues.
Making a backup and doing a fresh install might be best route.
Mh yeah I guess, with a message like that
So I guess I’ll get that USB stick out after all…
Any system stuff I should look out for and backup in particular
Gonna do my /home
separately, but I’m not sure if I need anything from /
otherwise… probably backing up fstab
for the UUIDs but other then that I don’t think I need anyone else there? Anything come to mind?
I’d like to get a list of my manually installed packages, but as mentioned in the initial post, neither DNF commands seem to work for it. Is there another way to get it easily other then grepping and sifting through 900 DNF entries?
yeah i like to tar up /root /home and /etc as a minimum…
if i know i have stuff in /usr/local… then i’ll grab that too
but those few dirs usually take care of anything i need to reset my pc with a fresh install
could try dnf history list
or just rpm -qa | sort
and then do a diff on it after you isntall fresh to see whats missing
Yeah that’s the 900 entries I’m talking about
grep
ing for installs should do most of the job tho…
I guess that’s a possibility but that’ll also list all the dependencies that were auto-installed, right?
Guess it won’t hurt to have the list tho, so thanks for that.
