… sorry for too many questions
… I installed kernel-devel-4.15.9-300.acs.fc27.x86_64
akmods wrote me that no akmod packages found
I try Xorg -configure , but - no result
… tried to remove xorg.conf - the same result
“…no screens found…”
beause akmods can’t find the packages mustn’t be using the proprietary nvidia drivers, what does /var/log/Xorg.0.log say when you run startx?
You should never use pci-stub. that’s been replaced by vfio.
pcie_acs_override
is the correct parameter.
Looks like I need to update my package.
Thank you!!!
… there in the log: “failed to initialize the nvidia kernel module”
How did you install nvidia drivers?
… I have nvidia drivers installed during installation virtualization package …
UPD: I uninstalled nvidia driver now and then x-windows starts with nouveau
I am happy now ))
I started win10 with my new usb-hub card - so I don’t need passthrough usb ports any more)
Thank all of you !!!
It’s a big deal for me )
Update: I’m currently building the ACS patch into the latest Fedora kernel.
https://copr.fedorainfracloud.org/coprs/kebrx/QEMU-Patched/build/736944/
Update should land this evening.
So, 4.15.14 was released. Working on the package now.
I’m aware that the packages are out of date. I’ll be updating them in the next 48 hours. I’ve got a lot going on at work right now.
I need to update both QEMU and Linux.
EDIT: the new version of QEMU will will include looking glass ivshmem patches and side-button support for the virtual mouse device.
Lots of builds in the queue right now, probably not going to be ready until tomorrow. (Too bad I can’t upload my own binaries)
QEMU Build: https://copr.fedorainfracloud.org/coprs/kebrx/QEMU-Patched/build/740070/ Failed.
Kernel Build: https://copr.fedorainfracloud.org/coprs/kebrx/QEMU-Patched/build/740071/
EDIT: QEMU build failed. Here’s the new one: https://copr.fedorainfracloud.org/coprs/kebrx/QEMU-Patched/build/740110/
@SgtAwesomesauce I guess your repo is the only one that currently exist? it’s for intel under fedora 28 ?
By the way does anyone of you have a wiki page or something that explain what’s an ACS patch and what’s the acronym for and what’s the same thing about npt?
I’ve stopped maintaining the repo. I simply don’t have time to maintain a passthrough VM and I sure don’t have time to maintain the kernel patches with proper testing.
That said, this is another repo to sort that out:
https://copr.fedorainfracloud.org/coprs/jlay/kernel-acspatch/
NPT stands for Nested Page Tables. Here’s a whitepaper on it. It’s a bit dry, but you’ll fully understand it after you read through:
ACS stands for Access Control Services. What’s important to you is that ACS is how the kernel builds IOMMU groups. Using the ACS override, you can separate all the PCI devices out into their own IOMMU group, allowing you to pass a single device to a single VM.
I wrote about ACS briefly in this article:
