I’m happy to announce the second crappy repo that I maintain!
I’ve been mildly frustrated with Fedora’s lack of “up to date” multimedia packages, so I decided to update them myself.
https://copr.fedorainfracloud.org/coprs/kebrx/multimedia
This repo is currently only home to MLT (6.6.0) and Kdenlive(18.04.0), but I’ll add other bits of software as a need is found.
If you have a package request, please post here or PM me. I’d be happy to add it!
To use the repo, use the following command:
sudo dnf copr enable kebrx/multimedia
Then just sudo dnf update
and you’ll pull down the updated packages.
Baz
2
Thanks for the effort! I’ll throw you a couple of beers soon, gunnah test these out in the coming days.
Turns out it’s not ready yet. I’ll update as soon as it’s done!
I’ve got to build a few packages from RPMFusion. (Fedora Project doesn’t like people linking to RPMFusion because of licensing issues)
EDIT: Looks like I’m going to be building ffmpeg and all deps.
Baz
4
Don’t sweat it, take your time. Lettuce know when you think it’s ready
Project build status:
[x] nvenc
[x] opencore-amr
[x] vo-amrwbenc
[ ] x264
[ ] x265
[ ] xvidcore
[ ] ffmpeg
[ ] libquicktime
[ ] xine-lib
[ ] mlt-freeworld
EDIT: dammit, x264 and ffmpeg: circular deps.
EDIT2: Screw this, I’m going to move this repo to my own infrastructure so I don’t have to worry about fedora getting upset.
