I’m trying to install Fedora in my new Ryzen build. I can get into the live usb but it’s very slow and unusable. I’m very new to this so I have no idea how to start troubleshooting.
You may have to remove gtx 1070 and get through the install process and install proprietary nvidia drivers then shutdown. Install 1070 and crank it back up.
No need to remove the gpu, at grub, select the kernel and press e, then add ‘nomodeset’ to the end of the line (seperated with space, no quotes) line with
’stuff quiet splash something’
press ctrl-x
Thanks again. Now for the drivers for the 1070 I’m seeing conflicting info on Google. Do you guys have a recommended guide or am I thinking about this to much and is just as simple as installing the drivers.
Actually that link is pretty much the same as what i’ve been doing, but to make life easier, after step
2.6.4 Remove xorg-x11-drv-nouveau
press ctrl-alt-f2 to open another TTY, login
$ sudo systemctl stop gdm
(might have to ctrl-alt-f2 again)
$ cd Downloads
$ sudo ./NV
(just press tab & enter)
When the install finishes, run
$ sudo dracut -f && reboot
Might wanna consider disabling kernel upgrades too whenever you update the system to avoid borked drivers, if you want stability that is. Fedora is cutting edge and proprietary drivers doesn’t go too well hand-in-hand with that.
Afterall, you don’t need to upgrade the kernel everyday anyway.
Since both are on their respective drives everything’s fine and dandy.
If they were on the same drive, windows might overwrite grub while fixing its boot partition
Note that I would HIGHLY recommend against Baz’s advice to freeze kernel updates. Doing this will prevent you from receiving security updates, bug fixes, and improved hardware support. Instead, I would recommend using the negativo17 repo’s nvidia driver packages. This way you will receive automatic updates for the Nvidia driver to support new kernels and it will automatically rebuild using dkms on each kernel update. Worst case scenario if a kernel update happens faster than the nvidia driver can keep up and it fails to load, you can just select an older kernel at your grub prompt.
