Did you ever figure this out, I’m having the same issue on Debian 9 with this patch and 4.10.1 kernel.
I patch the source without error, and build and install the kernel, then boot from it, but I can’t seem to get my 1x PCI-E devices out of group 15.
I have a Ryzen 7 1700 with an ASUS B350-F logicboard. I’m trying to split my 1x PCI-E slots to be in there own IOMMU Groups, but I’m not having any luck.
I downloaded a ACS patch, as well as the kernel source for 4.10.1. I applied the patch without error and did:
make nconfig ( saved the default config )
make clean
make -j16 deb-pkg
All went without error and I installed the resulting .deb.
`sudo dpkg -i linux-image-4.10.1_4.10.1-1_amd64.deb`
That went without error, and I rebooted my system from the new kernel, however I can’t seem to split any of the 1x PCI-E devices.
I have, what I think is the correct kernel command:
Command line: BOOT_IMAGE=/boot/vmlinuz-4.10.1 root=UUID=258e1e27-c00d-46f7-9204-40f3132ddd79 ro pcie_acs_override=downstream quiet amd_iommu=on rd.modules-load=vfio-pci vfio_iommu_type1.allow_unsafe_interrupts=1 video=efifb:off
I can’t seem to figure what I’m doing wrong?
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 10 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 11 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1454]
IOMMU Group 12 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
IOMMU Group 12 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 13 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1460]
IOMMU Group 13 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1461]
IOMMU Group 13 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1462]
IOMMU Group 13 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1463]
IOMMU Group 13 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1464]
IOMMU Group 13 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1465]
IOMMU Group 13 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1466]
IOMMU Group 13 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1467]
IOMMU Group 14 01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd Device [144d:a804]
IOMMU Group 15 03:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43bb] (rev 02)
IOMMU Group 15 03:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b7] (rev 02)
IOMMU Group 15 03:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b2] (rev 02)
IOMMU Group 15 1d:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 15 1d:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 15 1d:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 15 1d:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 15 1d:07.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 15 1e:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 15 1f:00.0 Network controller [0280]: Broadcom Limited BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03)
IOMMU Group 15 22:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108GL [Quadro 600] [10de:0df8] (rev a1)
IOMMU Group 15 22:00.1 Audio device [0403]: NVIDIA Corporation GF108 High Definition Audio Controller [10de:0bea] (rev a1)
IOMMU Group 15 25:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 03)
IOMMU Group 16 26:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480] [1002:67df] (rev e7)
IOMMU Group 16 26:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:aaf0]
IOMMU Group 17 27:00.0 VGA compatible controller [0300]: NVIDIA Corporation NV43 [GeForce 6600] [10de:0141] (rev a2)
IOMMU Group 18 28:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:145a]
IOMMU Group 18 28:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Device [1022:1456]
IOMMU Group 18 28:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:145c]
IOMMU Group 19 29:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1455]
IOMMU Group 19 29:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 19 29:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Device [1022:1457]
IOMMU Group 1 00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 2 00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 3 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 4 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 5 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 6 00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 7 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 8 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 9 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1454]
My 1x PCI-E devices always end up in the same group as everything in group 15.
