So I installed Fedora 25 alongside Windows 10, and after I grabbed the updates from the Software program, (one of which was a kernel update to version 4.9.5 that I suspect is the cause of the issue) none of the three Fedora partitions will boot past the Virtualization Daemon. The partition with kernel 4.8.6 doesn't even boot that far, it hangs on the first line and just says "[4.421458] sp5100_tco: I/O address 0x0cd6 already in use"
Hardware?
Not at home right now so I can't give you exact details, but off the top of my head:
A8-6600k stock clocked,
EVGA 750 Ti stock clocked
MSI FM2-E35MA motherbosrd
Samsung 230Gb SSD (this is where all the OS' are installed)
1TB storage drive I ripped from a Seagate external enclosure
