So. Where there’s rust to see, there’s a lot more that you don’t…
Anyway, one weekend of work later the bottom of the car is rust free.
And sprayed down with undercoating that is now intact again.
The threads on the screw holding it down stop halfway. so i threaded them to the bottom. and i had to bend the legs of it because this intake case is a lot lower than the original.
afterwards i sanded, primed it (with rust converter) and painted it with wheel paint.
Once it hardened i made a hole for the air temperature sensor.
Made mounting hole a little bigger (because it did not fit by a few millimeters).
and voila.
The tube going to the “top” of the filter is the stock way of providing air.
I just cut it to length and put it againtst the top of the filter.
I have plans to add another tube from the bottom of the car towards the filter to shoot cold air at the filter.
When i stop the oil leak at the distributor i’ll clean it all up and put a new filter on.
The sound is crazy! It now has a really profound intake sound.
The tubes are now so much shorter and way larger.
I almost can’t believe the car could even run with the stock tubing and filter.
It really did restrict in this case!
The RPM’s increase much more rapidly and a bit more steadily on WOT.
It not only looks better then the retarded way the previous owner did it.
It also works a lot better because the way the previous owner did, it still had to suck trough a very little hole.
Now, not anymore.
Update after a little while.
I removed some rust from the front of the roof.
not the best job, but i look at it as removing a tumor and leaving a scar.
The height of the car has also changed a lot! it sits way higher than it did before.
For the rubbing part i-am thinking about getting some of these things.
