But then again if one thinks about it, there's no point in overclocking that high anyway if you can't bench it, that's like boosting a car 1.6 Opel Astra to 900Bhp but having the engine blow up while racing it. Awesome, but impractical. I love practical mods more than show mods. But that's just my view on things
Ok, Now not to detract from that achievement. I thinks it's awesome. The 5.3 OC gets more praise from me as such because they also got a cinebench result out of it atleast.
EDIT: Afterthought, As for LN2, why are all these OC'ers still using open evaporation LN2 cooling, surely someone has made a closed loop recirculating LN2 or Helium Cooler by now?
Well at the temperatures ( < -20C) LN2 cools silicon down to, the properties of silicon change in many ways, It's thermal and electrical resistance decrease so you are already outputting less heat, but the silicon and chip assembly as a whole also becomes more brittle and prone to cracks. So there's a fine temperature balance between voltage and temperature. As for trace etching, you will likely end up with some transistor junctions and weaker circuit elements heating up substantially due to simple Ohms Law alongside with a whole bunch of other effects such as electron leakage etc due to the higher voltages at the small scales involved.
That said I'm not an expert on IC thermodynamics and design that's just my educated guess/idea of what I think plays a role In short form.
Thinking of the magnitude of a project like this made me chuckle... a closed-loop cryogenic system? That's hopelessly preposterous on a lot of different issues regarding size and cost for a personal computer based on everything I understand about the subject (which is, admittedly, limited!)
Well you gotta go to the next step eventually, how else would we cool the 30Billion transistor chips of the future :P
But regarding Closed Loop LN2, I have seen a few of those in my time, mostly in research, the issue with them is just that the condensers and compressors are quite 'bulky' :P
But they would give you quite stable temperature control requiring relatively minimal interaction so would likely give stable 'extreme' overclocks for longer than a guy can pour LN2 from one cup into another. Lol
But honesly I'd be up for building something like that right now for my poor PC. The ambient Air temp right now is 41C where I am....
Intel just gives OCers like 10 CPUs in case some die then its like... Oh well. AMD...idk what they do for OCers, I would guess similar thing but not sure
