Fancontrollers & cables
I'm building a PC. Going with watercooling for the CPU.
I need three fans. I've decided to go with threeCooler Master Blade Master 120mm. I want to use the fan controller that comes built in the case.
I wonder do I need any extra special cable for that to be able to use the fan controlling buttons?  Or are the fan controll cables already in the case?
I think there is a sort of chip behind the motherboard mount which you will just connect your fans upto and that chip should be connected to the control panel installed.
thanks
Look for an unboxing and first look on youtube Linustechtips has a video which goes through all the features
I was mistaken and there is no chip in this case but the cables are already there and you will just connect your fans to the preinstalled cables
