Hey guys, I was wondering if you can give me some feedback. I just installed some 120mm fans on the top of my case, problem is I accidentally put them as intake fans. Me being the lazy guy I am and not wanting to deal with pulling out the case and re positioning the top fans as an exhaust. I already have two 120mm fans as exhaust, one at the back and one at the side.
I really don't think you will have a problem with the fans being mounted as intakes. My question is do you have more intake fans then exhaust fans cause if the air doesn't have a proper way to exhaust you will start to build up warm air pressure in the case. In my opinion you you should always have the same if not more exhaust fans as your intake fans.
Right now I have two exhaust, and three intake fans. Would it be fine to just leave it as it is?
Yeah I don't think that would be too much of a problem but, I would change at least one of the intake fans that are mounted on the top and change it to an exhaust. But really that's up to you, as of now you won't really get a lot of warm air building pc in your case.
The most efficient fan placement in terms of cooling is intakes in front and side slots and exhausts in rear and top slots, also having your CPU fans blowing towards the top helps by a few degrees. But you only care about that when you have to deal with a lot of heat, like having an AMD CPU and a high-end GPU with fans.
In your case you can just leave it as it is. Airflow will be kinda screwed, but you'll have less dust in the case because of air pressure.
Alright! I'll have the top two changed to improve airflow. Thank you guys for advice!
I recommend also changing your side fan to intake because you don't want negative air pressure (which gets more dust into the case)
Alright! I will do that as well!
