Fan not working
So my frontpanel-fan won't work. It's an Noctua NF-P12 PWM fan. I have hooked it into the motherborad, and I have checked the BIOS and it says it is working. Please tell me if I can do nything else than swiching it out.
Thanks
Sometimes PWM fans won't start spinning if they are being driven at 800 RPM or less, Try pushing the fan blades once when you start up the PC to see if it starts spinning. Another way of testing the fan is to drive it at 12v max using a molex to 4-pin fan adapter. If it still doesn't operate with direct 12v coming from a molex connection, your fan is bad and needs to be RMA'ed.
