Now I have recently made a post about how I am going to buy a new Aerocool DeadSilence 14cm blue led fan. So I can cool my gpu better I'll give you the gist. My gpu was running hotter then I'd like so I thought it was this case fan config here is that bit
So My case is a zalman z11 plus. When I bought the case I wasn't really aware of the whole positive and negative pressure thing. Here is a picture of the case and it's fans
You can't actually see it in these pictures but there are 2x exhaust fans, one in each side panel as part of Zalman's unique HDD cooling solution demonstrated in the following picture.
So I thought since there was one intake which most of was probably being taken up by the 2 exhuasts in the side panel never mind the other 2 exhausts at the back of the case. That installing a fan in the bottom (which is the small picture to the left of the internal case picture) as a filtered intake would help allot since
A It was literally pointing the gpu
B it satisfies the whole air should travel in the bottom right to top left and
C I was going to plug it in via molex hence max rpm
Sadly it kind of didn't I used heaven as a benchmark without the fan it hit max of 76 with about 70% fan speed
with the fan it hit about a max of 74 with a fan speed of about 65%
Here are the comparison pics
Without the fan
With the fan
Without the fan
With the fan
I mean I was expecting more at least about 5 degrees considering it's a 140mm fan running at max rpm facing the gpu with an airflow rating of like 64CFM
I'll attach some pics to see if I did something wrong. When I was taking the pics I felt over the fan and I really didn't feel that much airflow I think I mounted it as a intake right? well here are some pics
(Sorry I know it's kinda hard to see with the blue led)
If you are thinking about clearance there is clearance as you can see
I mean under there can fit about 1.25 tic tac boxes although that reduced a little because of the dust filter. I know this was a pretty long post but still
Thanks
