Hi everyone
So I bought a Cooler Master Storm Scout 2 case and 3 bitfenix spectre pro red LED fans.
The Scout 2 has a LED on/off switch and I bought those fans because the LEDs can be pluged to a different plug than the motherboard 3/4 pin fan connector. I wanted to plug those wires to the LED on/off switch, but they are both male :(
To get things even worse, the scout only supports 2 fan LED plugs and I needed 3 ( two intake fans and 1 exhaust ).
My question is: Can I use 3 pin connectores instead of 2 pin for the wiring?
