Fan LEDs causing system to short out?
Hello fellow Tek Syndicate members!
I have recently built a new computer system and decided to install a few fans. I bought 2 Bitfenix Spectre fans (Non-Pro Version) and decided to hook them up to my system. However they are causing a few issues.
The fans work fine on their own but if I were to plug in the Fan Led into a Molex adapter to my power supply, this would cause my entire system to short out and it would completely fail to switch on.
I have 3 separate adapters and I have installed 2 of the Bitfenix Spectre fans. Both fans work fine but the problem is that my system will not even switch on with the fan led attached. I have tried both fans and also all 3 of my adapters and this problem keeps re-occurring.
So I would really appreciate it if anyone could help me with this problem.I am using an FSP Hexa 500W 80+ PSU so i don't think that is the problem.
Any help is greatly appreciated.
The Fan LED (the 2 wires) are not for powering, the LEDs gain their power from the 12v of the fan input (3 pin). The 2 separate wires are to hook into a switch for toggling the LEDs
