I am planing on getting a case that supports 7 fans but the mother board I have only has 4 fan pins. How to get more so I can plug in all 7 fans? This is my first build..
I believe there are 4 pin connectors to molex adapters. Im not sure though.
No worries, this is often confusing for most people. You can get a fan splitter which can connect a number of fans to one motherboard header. Alternately, you could use a fan controller, but the fan splitters are a much cheaper solution. A single fan header can support up to ten fans, usually. Always read the motherboard manual to see how many they can support.
SWEET!! thanks.
