Fan controller
hey guys,
formy next pc i am gooing to need fann controler but i cnte find one that will work. So do you know any internal fan controler that can be pwm or some things like that?
it can t be one that goes on a 5.25" bay beacaus they will all be occupied
and it cant be PCI-E beacaus they will all be occupied unless the pci-e controler can fit 20 fans
thanks you guys if you can help me!
the only way would be to buy some fan splitters and extensions and run then from your motherboard. you ca also use this softwhere to control them using this: http://www.almico.com/sfdownload.php this is not easy to use but heres a guide: http://www.silentpcreview.com/article1275-page1.html
there are also external fan controllers like http://www.amazon.co.uk/NZXT-LXE-External-Aluminum-Controller/dp/B003VRK1GC you can find it on pretty much most big hardwhere distributers.
hope this helped :)
http://www.nzxt.com/product/detail/79-sentry-lxe-fan-control  outboard fan control
NZXT fan hub http://www.nzxt.com/product/detail/123-grid-fan-hub
