Fan config
I'm planning to build in the prodigy with the ASUS P8Z77-I Deluxe motherboard but have ran into an issue: fans. I'm planning to have 4 120/140mm fans running, but I only have 1 fan header and will be using my ODD bay for a blu-ray drive. I've made somewhat of a solution but need some input.
What I've got:
2x bitfenix spectre LED 120MM
1x bitfenix spectre pro 120MM
3x fractal design quiet case fans 140MM
1x xigmatek fan that came on xigmatek dark knight
I'm planning on using my xigmatek heatsink with push and having an outtake fan at the back of the case. These 2 fans (should) be able to use a fan splitter. I also plan on having either 3 120 or 140 MM fans running on the top, and the front, which would need a 3 way splitter (of which I haven't seen). OR, I can buy a 200MM/230MM fan (bitfenix sells for like 17$) and have 2 fans on the single fan header and 2 fans on the cpu header. Only thing is: will the differentiation in speed between the 200/230MM and 120/140MM fans cause an issue? ANy other possible setups would be appreciated.
Also: I've got a bitfenix recon fan controller. I'm planning on donating that to my survivor build because there's only 1 ODD bay in the prodigy (and I want to watch my blu-rays), but if that's the only way then I may consider it.
It's also worth noting that I'm in Canada, so my 2 major retailers are ncix.ca and newegg.ca.
You connect up to 10 fans on that single header, I believe. Just buy more splitters.
And I think Bitfenix sell some 3 way fan splitters, which are sleeved and look nice.
Search for Bitfenix 3 way fan splitter. Should return quite a lot of results.
The only site that carries them in Canada is amazon.ca, for $20 + $10 Shipping + $5 Tax. Comes to $35!
I think i'm better off getting a 200MM fan + 2x2 way splitters for $20 unless you know another site that ships to Canada or another product on ncix.ca/newegg.ca?
daaaayum
never saw that site, i'll have to look into their shipping, if not ncix has their 2 way splitter and i guess i can splitter my splitter. thanks so much :D guess converting to itx may be a reality
