Fan config with a nzxt x61 and a arc r2 mini
so basically im wondering if I need to reconfigure my fans.   I have my top fans (2x 140mm with rad ) intaking and front fans on intake duty as well with the bottom 120 and back 120 as exaust.  the front and top are filtered. as well as the bottom.    also I have a 680 lightning for graphics.   can I get better temps with a negative pressure setup vs the positive pressure setup I have now?   currently nothing is getting hot,  but my vrm heatsinks would most vunerable on my cheap msi z77 board with a 4.3 ghz oc on the cpu....   im guessing im overkilling on cooling and don't need to worry about it....  am I right or should I reconfig my fans for neg case pressure?
well im personaly not realy a fan of using an AIO as an intake, because the the air that gets trough the rad, heats up and get into the case.
i personaly would advice to make your krakan as exhaust.
front + bottom input.
back exhaust or input thats something you could play arround with.
why would they filter the top if its exaust ?  to keek dust out when the case isn't in use?
Yep - exactly that.
You always want exhausting air to be up and backwards - heat rises
