Fallout 4 Survival Mode
I recently started modding fallout 4 and turned off survival mode to make it easier to test the mods and cant find a way to turn it back on. Anyone know a way to turn it back on?
Just go to settings and then gameplay should be an option for difficulty.
After I changed it to a difficulty that wasn't survival the survival option was removed
Survival itself is a difficulty level, I don't think you play on say, normal with survival. It's all or nothing.
Yeah I know this already but I changed to a different setting and wanted to change back but it wont let me so would I need to start a new save or is there a way to reactivate it
That's strange, I've been able to go back and forth before. I'm not sure what happened with yours.
Ok ill go back and double check
Nope its gone. Ill just start a new save I wasn't that far anyway.
I guess they have updated it.
Thanks for the Help anyway
I'll check my save when I get home today to see if its different for me now too. I'll let you know what I find.
Bethesda changed how Survival works and it was in beta for near a month on steam; It's pretty much survival mode and you can't change back to it on that character and have to start a new one.
only semi related to the OP topic.. should i give survival mode a try? is it good?
It is quite fun it forces you to explore more of the map with the whole no fast travel but it did get boring fast thats why I added the mods.
My two cents.
I cannot play survival without the quick save mod, I don't feel like playing dark souls, in fact I detest that sort of gameplay. It saves me the frustration of going allllllllll the way back to where I died with lost progress, so much wasted time, not fun.
Yeah that annoyed me too so I got a mod to add quicksaves to survival
