Fallout 4 58GB HDTP
Started to download a little while ago. Looking like the total download time is going to be ~8 hours 20 minutes total. Not too bad really.
Gotta get muh pixels.
Mine is just about done downloading. Took about 2 hours so not terribly bad. I'll post what I think of it.... not expecting much.
Edit: Doesn't look like incredibly different to me....
In case anyone is still looking for a side-by-side comparison, Joker Productions did a pretty decent job in his recent overview of the texture packs. Video
  • AK
Wouldn't be much easier use sweetfx to gain some eyecandy without downloading 58GB of texture pack that seems doing not that much?
Yeah, in 1440p...
For all theese ultra hd assets.
Honestly if you don't have a 4K screen you're probably not going to see the benefit lower-resolution stuff will just look smoother and a little bit more detailed
I am noticing quite a good difference but it's just wondering around things like boxes and containers really just pop
It like time loop/deja vu, over and over again - choices:
3D monitors: you can have 3D/60Hz OR 120Hz
4K monitors: you can have 4K OR 144Hz FPS
VR: you can have VR OR you can have 144Hz FPS
Yep looks great in 4k. Not so much in 1440p
Before: mud.
After: Sand.
Its fallout, I don't see the point. Something moves, shoot at it.
Geez that's fast internet, the fastest I get is 17 MB/s
andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/andthenextday/...
I agree... no difference in quality at 1440p. No 4k to test on though.
check out a mod called OVERGROWTH
resurrection>all other plant mods
imersion scientist have confirmed that radiation does not kill plants, it helps them by killing their predators.
edit taken down from nexus and it's currently hosted here
Wait a minute.. Are the ultra high res textures loaded and running in those pics? Because some parts look garbage..
i'm not going to jump and shout over it, but i really really really fucking wish Bethsoft would understand that they could've done this all along, IF THEY DEVELOPED FOR PC FIRST. it's not like you can run it past 59fps anyway, without physics bugging out. that means there's no point in updating your gpu for this down the road unless you just fucking adore 16k [or whatever] textures at the exact same FPS you're already getting.
besides, the textures in F4 seem to be a weak point, since tons of mods are devoted to making them run better. so are these the textures we would've gotten on PC had it been the favoured platform, or did they just upscale them?
It was a really awesome mod but they got in trouble by the nexus community for using stolen assets from other modders with out giving proper credit. Still needed some work though like some of the houses had really low res textures in the city.
If you play this at 4k you will notice the difference pretty fast, not all textures are created equal however, some seem only increased slightly such as slate rocks etc which do look better but not 4x better. I think its pretty good, however on my 980ti you can really tell the 6gb memory is struggling to stream the textures in at times!
Do the 4k textures completely tax all 6GB's of the card? I wonder if it's a limitation of bandwidth from the individual memory circuits; fully saturating less IC's, so total bandwidth of memory controller isnt utilized
Yes they tax 6GB cards pretty hard but its playable, just with stutters now and again (some pretty bad)
