Fallout 3 help
I give up trying to make it run. I've done all the core disabling bla bla everything. Previously I used an EXE file that did it all and it worked perfect, but I lost it.
If you done everything, then I'm not sure what else I can offer. And since you failed to specify a problem, I'm going to assume there isn't one, or you already fixed it.
But seriously, at least give a description of the problem? What happens when problem occurs? Specs?
Crashes @ start before even starting, right when the timer spins about half way.'
In the past I've had and solved the same problem on this exact laptop. Can't find the program though.
i3 2330M.
2x2G Of ram.
HD3000 graphics.
Is there an error message? Does it just hang on a blank screen? Or does it go straight to desktop?
Is this the official copy of the game, or a pirated copy?
Official, I bought it through steam.
Just crashes on start and I gotta end it in Task Manager.
Open your console by pressing ~ and type "pcb" without the quotes. this should clear the cache.
this worked for me. but i still get the BSOD after 30 mins or so.
I may be totally wrong, but could it be that the HD3000 just can't handle it? I once tried to run the game on my mother's desktop with a GT220 and it struggled something serious - for gaming the GT220 is quite a bit better than the HD3000.
I doubt it's that. I could run Fallout 3 and NV on my C-60 APU just fine, but it was bottlenecked by the weak CPU cores (20-45FPS). The Intel HD 3000 graphics should be slightly faster, not to mention it does meet the requirement of DirectX 9.0c compliant .
Have you tried running the game in compatibility mode (Windows XP, or Win2000)?
You've gotten the d3d9.dll file?  I know you said you did everything, but there's more "proven fixes" to get Fallout 3 out there then Carter has pills.
Anyway, that fixed it for me.
Yes it didn't fix it :S
I have previously ran it perfectly fine.
