cmoida
May 10, 2020, 12:49am
1
Hi there,
I am trying to get started with Looking glass. I followed the guide but when I try to run the client.
It crashes with a “Failed to create EGL surface (eglError: 0x3005)”
Any ideas what is happening and where I should look next? I am running the host on debian 9.4
Thanks,
Sure - Can you please list your hardware?
Assuming you’re using AMD gpu?
Have a look at this https://github.com/gnif/LookingGlass/issues/186
HI!
I am using an integrated graphics chip on the i7-8700K,
Intel® UHD Graphics 630
i am passing through a nvidia 2070
I already tried the suggestion of geoff in this post but I dont have a stack trace.
No stack.
Thanks!
gnif
May 10, 2020, 4:03am
4
cmoida:
Please try bleedinge edge, I beileve this issue has been resolved.
I tried bleeding edge but now I am getting different errors.
Thanks fgor taking a look!
gnif
May 10, 2020, 4:22am
6
The archive download doesn’t include the submodules and you need to use git. This will be fixed at a later date.
https://looking-glass.hostfission.com/wiki/Installation#Downloading
See the note.
Great I will clone the repo. Thanks!
Hello,
I tried to follow the instructions in creating the bleeding edge version that I checked out from GIT. I was able to get a client that would open although it then crashed.
I then realized that I needed to make the vm host executable also. This however is not working although I followed the instructions
Thanks again for taking a look.
gnif
May 10, 2020, 5:58am
9
Again you did not clone the submodules.
However, you don’t need to build the c-host, just grab it from the website. Scroll down for bleeding edge builds.
cmoida
May 10, 2020, 7:27pm
10
That still did not work. I am currently fighting with debian buster to try and see if that will work better. I’ll report back with success soon…
cmoida
May 11, 2020, 12:31am
11
So finally got it running after setting up debian 10! Thanks for all your help!
Do you know of any work-arounds for AMD pro driver users?
I need the PRO driver for Davinci Resolve and my endless hours of gameplay on Overwatch on Arch Linux. But I want to be able to access my Windows VM without having to switch drivers all the time
gnif
May 17, 2020, 6:21am
13
Don’t use them, they are not needed. OpenCL can be made to work without the entire AMD pro driver suite.
Ahh I see.
Is the any OpenCL package in particular I should use?
