Eyefinity question
hey i was just wondering what you guys think would be better for 3 monitors in eyefinity
the asus vg248qe
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236313
or the asus vn247h-p
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236307
i like the thin bezel but i also like the 144hz
let me know what you guys think would be superior to the other
Go with the asus vn247h-p.
One, it's way less expensive; especially when you're getting three of them. Use the left over money for another GFX card as it'll be much more beneficial.
Two, you probably won't be getting 144Hz in any game that isn't three or four years old at that resolution with max settings with any eyefinity set-up that doesn't already have two or three 7970's. Refer back to point one unless you already have three of them.
Lastly, you'll rather have the small bezel. The small size dif. won't make too much a dif if it does at all, and other than that and the Hz everything spec-wise is the same.
go for the asus vn247h-p
ok sounds good i kinda made up my mind after i posted on the vn247h-p's but i like having other peoples opinons im going to run 1 gigabyte gtx 770 4gb card unless i get reallly lucky and can buy another one......plan on playing games such as MINECRAFT,BF3,BO2,WOW,LEAGUE,RIFT,ARMA II,CRYSIS 3,FARCRY 3, RUNESCAPE(lol), SLPINTER CELL BLACK SOMETHING, ETC  and was hoping to be able to play metro last light and 2033 but if i want to play those i can turn off 2 monitors
