I currently have 2 7950s in Crossfire and I have been following PC Perspective and their frame output benchmarks pretty closely. I can say first had that I noticed a huge improvement in the smoothness of frame rates once I got the frame pacing 13.8 beta driver and now I have the 13.10 beta. But I really want to get a triple monitor setup but it doesn't seem worth it if they cant fix the problems Crossfire has with Eyefinity.
Can this be fixed through just a driver update? I feel the only option if it isn't fixable through just a driver is to SLI nVidia cards, but I would have to get a 4GB card as I don't feel that a 2GB frame buffer is large enough for those resolutions. Any thoughts on if my future looks bright with my current setup or is nVidia the only answer?
I think a lot of the problem is DirectX. This is why AMD is/has developed the Mantle graphics API. The problem is rooted in the overhead from command translation in DirectX's API structure. OpenGL sees less problems with this as it is a lower level access than DirectX. But, Mantle is promising hardware level access without the need for command translation in software level access. Because Mantle talks directly to the GPU it will probably be supported by all AMD graphics cards. I would hold off on multi-monitor eyefinity display configurations for now with crossfire configurations till Mantle has been accepted into the game development community.
Well correct me if this assumption is wrong, but if Mantle can fix this problem might I be able to run Battlefield 4 in Eyefinity? I would really love to rub that in all my COD playing Console loving friends faces! In the most friendly way possible of course.
This is all speculative, but only if AMD updates drivers for every previous generation that is still relevant to allow Mantle to talk to the GPUs. We don't know enough about the new API to make assumptions. Based on what has been discussed though Mantle should open up a whole new world of possibilities for game development, including better optimization for games like Star Citizen to eke out as much performance from current graphics options as they can. Considering most graphics cards can barely run the game at 20 FPS with minimal graphics options enabled in a single GPU configuration.
Your subjective view of crossfire eyefinity is skewed. They have not released any improvements for crossfire configurations with eyefinity in the new beta drivers. It's entirely possible that you may not see the frame latency as not everybody's vision is the same.
I see some frame latency in Unigine Heaven, but my take on it is the frames per second are running so high, there should be no way to see the lagging frames. But yeah, it is a subjective view, as we don't have any scientific evidence on how the eye works.
that is the PC Perspective video using Crisis 3 to show the microstutter and frame tearing that Crossfire has in eyefinity. To me the gtx 780s in SLI are just buttery smooth and the 7970s in Crossfire are just a little jittery. I know they have plenty of power to be as smooth as the gtx 780s but they just aren't.
If you go to this video Ryan talks about how he has made AMD aware of these problems and they assure him that they are working on a fix. He starts talking about it at the 12 minute mark.
The drivers they have released so far fixed the issue with single monitor resolutions up to 2560x1440. I do feel like my gaming experience is butter smooth on a single monitor.
