This summer, after I get back from Basic for the Army, I would like to sell
(or give away), my old low budget PC and build an insane water cooled PC.
I may not have the time (or money) to do it all at once. But, I would really
like to build something extreme and be able to use it not only for gaming
but for everything else including rendering and Auto-CAD. I have a parts
list partially. Some things may change, it just depends on what is out 4-5 months
from now and how much money I'll have after moving. I will be providing links to
products by the way, and any suggestions or comments would be greatly appreciated.
Parts list:
Parts list:
Case: Corsair 900D, or Caselabs MAGNUM STH10
http://goo.gl/GfCBv http://goo.gl/11zMN
Mobo's: http://goo.gl/3hOsW http://goo.gl/gogkT
Reservoirs; using both:http://goo.gl/7UL6F (I picked this one because it looks cool and you can attach pumpsin the rear for a discreet look)http://goo.gl/cFiac
Waterblockshttp://goo.gl/gBzTn http://goo.gl/6C0ts
RADS http://goo.gl/ZpXqe http://goo.gl/MpbsS
Tubing http://goo.gl/lhX2B
RED and BLUE coolant for two loops.http://goo.gl/g79tM http://goo.gl/ELzbR
FANS NB-Silent Pros and NB-ELOOP's.(Would like to do just pull configs, but because I'm going with 60mm RAD's,I might end up doing push/pull configs with both sets of fans. E-LOOP's inpull because they generate more CFM) http://goo.gl/R1qOH http://goo.gl/Fl9KX
Controllers/Monitoring Hardware/Software Koolance TMS-205. It looks like I can not only monitor,but control fans, pumps etc, so it's like an "all-in-one"system that I can just velcro or stick on with double sidedtape on the back of the motherboard tray or down belowon the bottom RAD.http://goo.gl/f4oY7
Thanks, like I said this won't be done for quite awhile and,even though I've done a ton of research and many hours ofwatching Youtube reviews, it gives me room to change partsand consider other possibilities.
**UPDATE- Going with Mushkin RAM if it's supported. If anyone can find me a list of the ram the ASUS Rampage IV Extreme LGA 2011 Motherboard that would be great.
**UPDATE- I've decided to just go all out, it's going to take longer, but in the end I think it will be worth it. The case is NULL, I had to substitute the 900D for something else around that price range. http://pcpartpicker.com/p/Dsdj
