So I put together a extreme budget build, the only thing I immediately plan to upgrade is the psu.
http://pcpartpicker.com/p/2eAk7
How does it look?
How does it look?
use the red bone instead of that case
I just got a new pc to day for $300
http://pcpartpicker.com/user/GhostMistSniper/saved/32MW
The cpu and motherboard were part of a combo but you have to go to a microcenter store to buy them.
I already had a HHD it's just a 2.5" 500gb drive.
If you have a microcenter near you I would give it a look for the combos with the cpu.
heres a link for the combos with amd cpus
http://www.microcenter.com/site/products/amd_bundles.aspx
Have you hooked that pc up because the motherboard only supports up to 1333 ram and you have 1600 ram
the ram runs at 1333 in this board but it can go faster if i over clock it. It does not do much for performance so I don't.
