Hey guys
i was wondering if anyone could reccomend a cheap GPU that can be used to run two 1080p monitors to have extra windows of chrome and skype and itunes and whatnot while I game as mentioned in the $5000 dollar editig rig video.
thanks!
Hey guys
thanks!
perhaps there is a way to use the integrated gfx at the same time?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130788
uses very little power, still new technology, 2 dvi, still gives a tad of performance
looks awesome. Although it does have a tiny fan. Will that one make a ton of noise, because i couldnt stand that, I dont think.
makes little noise becuase it doesnt spin very fast. it doesnt have to cool a huge heat sink.
awesome, thanks
