i don't really know what happened with my previous attempts at posting a topic. it links to some feb23, 09 topic here that was closed..
anyways.. heres my third attempt to raise my question..
i have my fans set up like this currently.
and i just installed a scythe kama bay up front.
im thinking about mounting another xigmatek orange fan on the scythe kama bay.
if i mount a fan on it, there'd be around a 13cm space between the "to be mounted" fan at the front of the 5 inch bays and the already existing fan placed at the back edge of the 5 inch bays.
would adding the fan be worth it? my concern is that it might lead to airflow inefficiencies instead of improving airflow.
i think it wot be worth to add one more: u have much fans installed and anone more at the wrong place could do bad airflow so if your pc is cold enough u dont need more fans OR instead of spending hundreds in fans you better get a watercooling for cpu and gfx card
Well, if your temps isnt bad, you probably wont need it. Also, if you have for instance two super fans, adding another one wont lower the temperature much.
Edit; lol I just found out how good the 900's airflow is.. When I turned the two front fans off, they kept on spinning, because of the outtake fans. when I opened the sidedorr, they stopped spinning. lol
It looks like you got an ample amount of fans already. If your temps are ok, then i dont think its worth it for the extra money, time, and possibily noise.
