What is the best bang-for-the-buck eternal WiFi antenna (one that works off USB). There are some weak signals I want to reach.
I can't believe i accidentally made this a blog entry before....
under $50 would be a plus
I'd go with this one:
http://www.amazon.com/Alfa-AWUS036NHR-High-Gain-Wireless-N-Strongest/dp/B005ETA5K2/ref=sr_1_1?ie=UTF8&qid=1373966603&sr=8-1&keywords=alfa
I have one myself. It's very good.
Note that it's probably illlegal to broadcast at more than about 1 watt where you live. The drivers will know this and scale down the power output of the antennae automatically. You could always override that limit though ^^
EDIT:
If you want even better reach you could go with this one and get a directional antennae too. If you know where the networks you want to reach are.
