Hi guys,
Is there any way I could use an external mic as a recording device when recording a video using my Xperia P? Are there any apps that can create such thing?
Thanks!
Hi guys,
Thanks!
Any pair of headphones with a inline mic would work to my understanding?
Hope it helped???
I just wanted the mic (Just for recording video). Like a mic attached to an DLSR. Come to think of it, I don't think it is possible. Thanks for ur help anyways.
No, USB host is supported on your phone, however, I tried with my Blue Microphone in my Xperia S and it decided not to work.
Read this post and be enlightened: http://android.stackexchange.com/questions/15404/is-it-possible-to-connect-a-usb-microphone-to-an-android-phone-or-tablet
However, i you sre any good at porting Linux scripts into Android Java, then, you may be able to :)
