Sure there is. Now this brand may or may not be available where you are, but it’s more than likely an OEM rebrand. That one was about 25€.
Find what is available locally, go to the manufacturers website and you will probably find more products in the same category, or just go with one SATA and one NVMe.
This one is SATA only and it’s fine. Nothing spectacular but it gets the job done and it took 30 seconds to disassemble. And it came with a handy screwdriver.
