my pc was in sleep mode when my dad turned off the power because we were redecorating and now all the files on the external drive where steam unity and x split are are all broken but the pictures and videos on the same drive are fine.
when i try to install it again it come up with the steam error 1327 and i used the steam fixer to try to fix it but it done nothing and now my computer tells me this when i try to open steam, x split or unity
the drive or network connection that the shortcut 'steam.ink' refers to is unavailable. Make sure that the disk is inserted properly or the network resource is available and then try again
i have tried starting my pc in safe mode though i doubt that done anything and i cant uninstall any of them because i get the same message. I have unplugged the drive and plugged it back in and that done nothing. i'm not sure if i should format the drive because the deletes everything off the drive.
i need help with this one.
