Did a quick search in the forums for this topic but couldn't see anything.
So I set up a Win10 VM on Linux Mint in virtual box for some work related applications/email (Google via EM Client) for work and I made it the recommended 32gb I'm now finding that I need around 50gb to be comfortable as some of the files for the Take off software I'm using are a bit larger than first expected, I do have the application pointing to Google drive but the sync files are chewing up some space..
in doing some research on line there seems to be a few different opinions running around that it can and can't be done
before I explore the option of cloning the drive and messing around that way I was looking at doing it through the terminal I have been following this guide
HERE http://trivialproof.blogspot.com.au/2011/01/resizing-virtualbox-virtual-hard-disk.html
and I am getting the error Syntax error: Invalid parameter 'Work'
the file name of the .vdi is Win10 Work Install is the wording of the file name messing things up ? or am I completely messing things up ?
any advice from the awesome community would be great
Thanks in advance
