Expandable media storage
ok so i posted a few weeks ago about a server set up i have looked a little more into it and am not sure if i am in the right place
i basically want to have a media server looking to build into a desk ... now i was looking at a mini itx board with 3 pcie x1 slots and getting 8xsata pcie adapters .... now my issue is that i have 16 tb of data so far on 4 x wd red drives. i want to be able to expand this a few hard drives at a time and i want to have the media backed up
i was thinking of running server 2008 and then buying 2 drives at a time and mirroring them  using 1 as a primary to add data but not sure if this would work .. any assistance would be appreciated
ps the server will eventually have 24 x 4 tb hdd for 48 tb data when mirrored( hopefully )
thank you in advance
I use snapraid. It's good for media files that don't change often. You can add new drives easily and assign drives for parity so if a disk fails you can restore it. It works sort of like RAID5 except it's not real time and if more disks fail than you have redundancy for you don't lose all you data, just the disks that failed.
I'm probably not explaining it well but check it out if you're interested in redundancy without the risk of losing all your data.
Dexter Kane this may well be the solution i was looking for thank you so much i will look into it and do some much needed research but this looks like an awesome start
greatly appreciated
P.S. if any one else has used snapRAID then your input will also be greatly appreciated
