Exhuast fans are loud
Hey guys, so I recently re positioned my fans from intake to exhaust. They are on the top of my case, and my problem right now is that, when they were intake they weren't noticeably loud. Now when they're exhaust it's noisy.
The case that I'm using is an MSI Interceptor Ravager and the fans I am using are the Corsair AF120 and all my other non-stock fans are AF120s. I tested where the sound was coming from by turning the top fans off first and bam, they were the culprit. Can anyone help me with this? and another answer is that they are not connected via the motherboard; however, the other fans are not connected by the mother board yet they are still quiet.
If they are connect ed straight to power supply without going through a fan controller then they will run at full RPM. AF120s are great fans for airflow but at the expense of being noisy.
Now, these fans that were previously set as intakes, the fans that you swapped them for were the stock fans I assume? While set as intake the AF120s will keep the most of the noise on the inside of the case (excepting turbulence) whereas set as exhaust you'll get most of the noise.
Something you can consider if you are running the af120s via molex is either run them through a fan controller so you can turn them down when you are not running anything too intensive and then crank them up when you need them, or pick up some 12v to 7v or 5v fan adapters that will set them to run at lower RPM.
Ahhh I see, what non-premium fan controller do you recommend? I only have four, 4 pin connectors and I use them as splitters for my fans.
Not sure for non-premium stuff. Depends on if you want 5.25", 3.5" or pci slot fan controller and how many fans you need to control.
Something like this for example: http://www.ebay.com/itm/3-5-PC-HDD-CPU-4-Channel-Fan-Speed-Controller-Control-Led-Cooling-Front-Panel-/400534744102?pt=US_CPU_Fans_Heatsinks&hash=item5d41bb2c26
or this: http://www.ebay.com/itm/Red-Blue-LED-8Watt-5-Channels-Mesh-Fan-Speed-Controller-5-25-for-PC-CPU-Case-/310808079698?pt=LH_DefaultDomain_0&hash=item485d9aed52
