I am curently having problems with my EVGA sr-3 dark. I am using the sr-3 dark, an w-3235 qs, a 16gb stick of ddr4 ecc, and a nocutua NH-U12S lga 3647. Any ideas would greatly help! The cpu gets hot and the fans spin but still post code 00.
dead cmos battery
Already replaced
As in single stick?
Have you tried it in every possible slot
I think it’s gonna want more than one, like at least 3
Here’s all the ideas that I have:
- Press and hold BIOS reset button while unplugged.
- Inspect socket and remount.
- Check EPS cables.
- Put known good stick of DDR4 in Slot 3.
- Try different PSU.
- Try flipping BIOS selector switch.
- Contact EVGA for replacement BIOS chip or if you can’t get one from them try getting from ebay. Do note and markings when changing the chip so you don’t put it in backwards.
it might be the qs CPU is not supported by the bios. there’s a way to check the bios what cpus work
I am going to try to flash the bios when I get home. Thank you for your reply!
