Hi all
Thanks for helping me out with the ram issue, which is fully resolved, but I need some help again.  I was about to buy the EVGA P55 LE, but they just ran out of stocks...  What they do have in store now are, the P55 Micro and some other FTW-like high end boards. This micro mobo has 2 PCIe 2.0 8x slots, and between the two, a tiny x1. I have to use this x1 to put my SB Titanium, and in order to do that, i have to put my GTX 260 in the second slot. Look at this pic here to get some idea bout what I'm saying...
So, if I install my GTX 260 in the second slot, will that work? I dont care bout the 2.0 x8 speed limitations, I just wanna make sure whether this will work at all. I might use the 1st slot to put in a 9800T or a GT 240 (single slot design, doesnt block the damn x1 slot)Â for dedicated physx processing, so all in all, will this setup actually work? it'll be like this:
PCIe no.1 x8>> 9800GT/ GT240 - PHYSX
PCIe no.2 x1>> SBÂ Titanium
PCIe no.3 x8>> GTX 260 (Main graphics card)
Is this a good setup, or should I wait and get that LE when it's in stock again?
Thanks in advance!!![img]http://gza.gameriot.com/razetheworld/default/smiley_bigsmile.gif[/img]
