EVGA p55 FTW 200?
I cant find this anywhere in the UK does anyone know where I can get one or the P55 classififed? Ive tried ebay and there is none on there either.
if you really want to sli
p55 isnt the best platform go i7
or jsut go fr the p55FTW
the nforce 200 is pretty usless if you look at the benchmarks
I was gonna go with x58 but then EVGA stopped selling the x58 mobo so I decided to go for the p55 ftw 200 as it can do real sli/tri-sli and I can use a i7, another reason is that its a bit cheaper.
evga is still making x58 boards lol? I can find them all over the place
but if you want just 2 was sli not even tri sli
P55 is not for you
definitely go x58
go asus or gigbyte if you cant find evga
P55 is not for you
definitely go x58
On evga's website the x58 mobo isnt available any more only the le and classified but i dont want them.
OMG I just checked and it says pre-order W00T they are coming back...YEY
Notify ME means they arnt coming back here is the one coming back as its pre-order, Â Â http://www.evga.com/products/moreInfo.asp?pn=132-BL-E758-A1&family=Motherboard%20Family
I thought Gigabyte had a shitty warranty? Maybe I'm the only one that buys things based on warranty.
You guys understand that you dont need life time warranty 10 years is more than enough as we upgrade our pc's atleast every 3 years
I know, but I thought Gigabyte outsourced it's RMA service to China. I also heard it was hard to get customer service on the line. Correct me if I'm wrong.
If I were you I would just go with a Asus board or a Gigabyte board. I can tell you that in my experience the dual bios can really help alot if you overclock or maybe push it too far and something gets corrupted like I have done at times.
The P55 FTW 200 has 2 or 3 bios chips
Has 3 IIRC, but if he can't find it ATM, and it would take a while to get them back in stock, might as well go with the next best thing, but thats just what I would do.
