EVGA Hadron Optical Drive
Right, I have the case and parts all set up, the only problem is I have no idea how to fit in the optical drive.
I have the EVGA slimline optical drive, it fits the mount just fine, but it doesn't fit in anywhere. Does anybody have any instructions, tips or even a video?
This is driving me mad. I just wanna get into my new build asap!
It mounts in the front of the case pointing out towards the right side panel (if lookin at it from the front)
If you look at THIS Look under the "Mounting the Hard Drive" You will see the butt end of the drive tucked in at the front.
It should slide into the right of the hdd cages if looking at it with the front to your right.
derp! Didn't even think to take the right side panel off.
Thanks guys. Just going to go sit in the corner and dribble on myself...
