EVGA Hadron Air build
http://de.pcpartpicker.com/user/Digeon/saved/39Qe
Greetings. I've been planning on building a new mini pc mostly for gaming and i've been on the lookout for quite some while. It's my first ever pc build and it might be somewhat difficult to put together but with online tutorials it shouldn't be that big of a problem. I was kind of leaning towards the Bitfenix Prodigy but the Hadron Air got my attention. So i'd like to hear your opinion and suggestions. Budget is around 1000 €. So here is the build i've been thinking of. Thanks
What platform do you want? Haswell? FM2?
I have that exact CPU/mobo combo. Good choice, especially if you have no plans to overclock. Looks like a good build imo. :)
Since your budget is 1000 but the build you listed is only 700, why not spend a little more and get a 780 or R9-290/X?
Actually it's 1000 but for some reason the price of the gpu doesn't register. Nice to hear about the mobo since i don't know much about motherboards.
Oh, I didn't notice that. Makes sense. :)
Yeah, it's a very m-ITX mobo, IMO. The onboard wifi is really nice. UEFI is fairly easy to navigate and it recognized all my hardware right away. Only thing I had to do was enable the XMP profiles for the ram. Everything else was set and automatic.
Not entirely sure what you mean but i'd say 1150 Haswell.
That sounds great. How about the wifi on the mb, what would you rate it. I wanted a wireless network adapter but partpicker would give me a incompatibility warning so i went with that mb.
The on board wifi works great and is a big part of the reason I chose mb. I play bf3/4 and other fast-paced online games and have had no issues with latency. It's pretty much just as fast as being hardwired to the network, as far as I can tell. My PC is located less than 10 feet from my wifi router, but really, as long as the signal is strong, you're good to go.
Looks good!  I wouldn't bother with that Arctic cooling, unless you don't like the look of the stock intel cooler.
The stock intel cooler is "ok". Highest temps I've seen thus far with my 4570 is low 60's and that's during heavy gaming with the GPU overclocked (making extra heat) and the case fans on high (node 304 with 2 x 92mm up front and 1 x 140mm out back).
The Hadron Air with the nice big side window, I'd be using a nicer CPU cooler as well. If not for better cooling, for the better looks alone. Probably something like a Hyper 212, but lower profile. ;)
The hadron seems like a nice case but has some flaws. But the node 304 is a trustworthy and tested case (i especially like the dust filters). MEC-777 what would you suggest seeing that you've got the case and pretty much the overall build i'm aiming for.
This is my system as it stands (CDN prices). Built it just a few months ago. http://ca.pcpartpicker.com/user/MEC-777/saved/34wL
I do plan on adding a better CPU cooler at some point, but I'm not sure which one yet. I know the Hyper 212 will fit as I've seen pictures, but it's tight. Cable management is challenging enough, so I'll probably go for something smaller but of the same design/style. The 212 evo/+ is a bit much for a non-overclocked CPU like the 4570, however I have seen it push itself up to almost 3.8 on all 4 cores (see pic below) quite a few times. So using something better than stock is not bad practice. Just make sure the fan is moving the air front to back in unison with the case fans and you're laughing. This case actually has very good airflow despite what some people might say or believe.
As far as aftermarket CPU coolers go, you don't need to spend a lot, but don't cheap out either. You get that you pay for. The one you had selected in your original build, by the looks of it, is probably no better than the stock Intel cooler, to be honest.
http://i78.photobucket.com/albums/j104/vtecthunder/Black%20Mamba/i5-4570at38_zpscaefc33c.jpg
I'll probably go with node 304, seems like a better choice especially for a first build although not really crazy about the looks of the case but i guess that's not really important. As far as the cpu cooller goes i would prefer to avoid the stock cpu cooler and so i just added a cheap one with the best rating. I'll probably start the build in about a month right after CES. Wanna first see new details on the steam machines. Thanks
