I just got into university and figured that I'd get a new PC, so this is what I got.
PC par list: http://pcpartpicker.com/p/1LqVr
For monitor, I bought a 32 inch 1080p TV.
Building it was scary. The card almost didn't fit in. I was considering GTX770, but 7970 just seemed to me like a better deal. So I forgot to consider the length problem when I was buying it.
If you are using this case for your build, DO NOT connect anything before you've installed your graphics card, or you'd have to remove them like I did.
The finishing result looks like this. I am using stock CPU heatsink. To be honest I think it looks dull and I'm slightly concerned about the heat. Tips on decorating/heat/cable management would be much appreciated.
Yeah I paid. I had to contact amazon custom support to get a refund. I wanted a replacement but they said that they could not do it even thought they have 1 in stock.... I got my money back but it delayed my ram by about a week. The status is still shipped now
