Evga GTX 760 vs 770
I am building a computer and I haven't decided on an Evga gtx 760 or 770. I want to know if I will get a significant performance increase in going up a card. I am planning to use the card with 3d vision in the future. Also, will the amount of RAM in the card affect the frame rate of the games while performing with 3d vision?
This will be my build
http://pcpartpicker.com/user/guineapigman/saved/2oeY
I don't know about ram usage with 3d vision but there is quite a big performance leap from the 760 to the 770. If you want a comparison, the 770 is like 7970 while the 760 is outperformed  by my 7950 so I'm guessing it's the equivalent of a 7870 or something.
I think the 770 is pretty much 1/3rd more in both price and performance vs the 760.
So it's a nice choice to make.
If you need that much more power, it comes at a very fair cost.
If you have the budget, you get a worthy gain in performance for the price.
I just got an Asus 760 and I'm really happy with it. I did consider the 770 but in the end I really just don't need the power. I can run almost all my games at max settings in 1920x1200 without any problems with FPS.
I'm not sure how 3D vision impacts things, probably more VRAM used for frame buffers etc. High VRAM 760's get expensive though, but then again so do high VRAM 770's!
Personally I think it'll be fine to just get a GTX760 with standard VRAM for gaming on one 1080p screen, even with 3D.
It's probably a bit more load than not using 3D, so maybe slightly less future proof, but not a huge amount.
By that time it's a problem just buy a GTX 780Ti or something for $250 used hehe.
